Old 11-09-2017, 08:39 PM   #14
Simon Rose
Simon Rose is on a distinguished road
Simon Rose's Avatar
2002 SL1
Default Re: Thermostat Issue?
I am in the Upper Peninsula otherwise I would be happy to use your scanner! The line is similar except on the SOHC it it a brass line running from the upper hose fitting (on the block) to the reservoir tank. Here is the only info I can find and the part does not seem to even exist any more.
www . wholesalegmpartsonline . com/products/gb/Saturn/SL/HOSE-Heater/2953240/21031145.html?partner=googlebase_adwords&kwd=&orig in=pla
It is part number "10" in the exploded diagram but I cant seem to track down a new one anywhere.
2002 Saturn SL1
Add to Simon Rose's Reputation
Rate the quality of this post and help Simon Rose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Simon Rose is offline   Reply With Quote
