Old 09-28-2005, 11:35 PM   #4
vlipke
vlipke is on a distinguished road
Default Re: Is this an option for the Ion?
it depends. Can you install one yourself.
If you can you will need the remote starter/alarm, wich will run you around $80 dollars for a long range good one.
Then you will need the bypass for the "coded ignition. Wich is about $30 dollars.
You will also need a couple of relays and diodes, and about 5 hours of free time.
If you want to have one installed figure about $300 dollars minimum. Atleast around here.
I dont have one in my ION yet, but my 2000 SC2 had one that I installed. It worked so well. I just opened the door to the rear of the plant that I work in, hit the button and it would start right up. Loved it. With the ION I am going to install a Audiovox alarm. They have an upgrade you can get that allows you to call an 800 number (free for life after the purchase) and start the car with a passcode.....
Add to vlipke's Reputation
Rate the quality of this post and help vlipke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vlipke is offline   Reply With Quote
