Old 04-16-2008, 09:29 AM   #14
JerryHughes
JerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of lightJerryHughes is a glorious beacon of light
JerryHughes's Avatar
1997 SL
Default Re: Replacing Engine/Trans.Mounts
Originally Posted by MikeNW View Post
After hassling with the lower tranny mount, while replacing my clutch, I would grind the lower stud a bit, it's too long anyway.
You need only one or 2 threads exposed beyond the nut, when it is snugged in place.
Thanks, I may do that. I'll feel under there and see how much I can hack off. I just wonder why G.M. would waste the steel when they don't have to? Usually a car company engineers a component right down to the least they can, to save money. After all, they are probably making millions of these. I'm wondering why all the extra thread---unless it makes assembly at the plant so much easier that it's worth using the extra metal?
Jerry
Add to JerryHughes's Reputation
Rate the quality of this post and help JerryHughes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JerryHughes is offline   Reply With Quote
