Old 10-21-2015, 08:17 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: 99 Saturn SC2 Steering issues this morning
It's kind of hard to say exactly without seeing the car. If you can it would be a good idea to have a shop(dealer or independent), look at your steering/suspension components if you can't yourself. It sounds like maybe the rack or the bearing in the intermediate steering shaft may be binding although on an S-series I've never seen one do that. I would also closely inspect the subframe and lower control arm attaching point areas.
Add to bluesl2's Reputation
Rate the quality of this post and help bluesl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
