Old 10-21-2015, 11:38 AM   #1
Kelevra
Kelevra is on a distinguished road
1999 SC2
Dazed 99 Saturn SC2 Steering issues this morning
Ok, so I searched the forum and didn't see anything... So here goes:
My SC2 was acting real weird this morning. It was about 35-40 degrees when I left, and I had difficulty turning the steering wheel. Then after I got back home from a short trip (about 10 minutes each way) the steering acted just fine. I let it sit for a while and had to go back out, about 55 outside, and the steering was acting stiff again, I had to make a tight turn to the right and there was a pop sound, but now the steering acts like it should again. I stopped my AutoZone while I was out and the clerk did some research on the computer and said it sounded like a problem with the Rack & Pinion. Does this sound like an accurate guess? If so how bad could this be to fix?
Add to Kelevra's Reputation
Rate the quality of this post and help Kelevra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kelevra is offline   Reply With Quote
