Old 03-04-2018, 09:43 AM   #3
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Default Re: Oil Consumption Thoughts
Atikovi,
I guess 'DESLUDGE' is the wrong word. More, DECARBONIZE, the tops of the piston, the rings, and the cylinder walls. Which then allows the rings to seal better leading to less oil blow by.
And, I remember that picture from my first thread about 3.6 timing chains issues. I am pretty sure that the sludge that you dealt with was was caused by low oil level leading to EXCESSIVE heat build up and the oil turning into that tar. And the low oil level was caused by the oil consumption issues and no one ever physically checking the oil level themselves. And this is where DESLUDGE comes in. I think that the methods I suggested to DECARBONIZE the tops of the piston and cylinder walls would also clean a lot of the gunk elsewhere in the engine.
I am sure that if I am wrong, someone more engine savvy than me will say something.
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
