Thread: XR gear ratios?
Old 11-24-2007, 09:14 PM   #3
yug
yug is on a distinguished road
Default Re: XR gear ratios?
Is this what you are looking for ?
Maximum engine horsepower
315
Maximum engine torque:
280 lb-ft
Maximum gearbox torque:
380 lb-ft
Gear ratios:
First:
4.48
Second:
2.87
Third:
1.84
Fourth:
1.41
Fifth:
1.00
Sixth:
0.74
Reverse:
2.88
Maximum shift speed:
7000 rpm
5-position quadrant:
P, R, N, D, (M)
Case material:
die-cast aluminum
Shift pattern:
(2) three-way on/off solenoids
Shift quality:
five variable bleed solenoids
Torque converter clutch:
Converter size:
258 mm
Transmission weight (kg / lb):
102 / 273 (wet)
Fluid type:
DEXRONŽ VI
Fluid capacity (L / qt):
9.0 / 9.5
Assembly site:
Warren, Mich.
Additional features:
Clutch-to-clutch operation (except 1-2); integrated transmission electro-hydraulic control module with driver shift control and performance algorithm shifting
Add to yug's Reputation
Rate the quality of this post and help yug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yug is offline   Reply With Quote
