Re: Entire vehicle (un)lock intermittent 2004 Vue
If any of the latches operated lock or unlock then all of the input devices are operating. I repair a lot of vehicles with several latches failing. What I have been seeing is a failing latch the manual lock button or lever moves a small amount when the first button press but not unlock or lock, sometimes will operate the first time and each button press after that will get worse,
I have replaced 2-3 latches on vehicles as low as 15,000 mile and then return a few weeks later for anther one failing. Replace latches as needed
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
