Old 09-04-2017, 10:52 AM   #4
Default Re: 2002 Saturn SL1 Quill Seal Removal
Beware that any attempt to hillbilly that bearing-seal assembly out of there results in a broken bell housing. The seal is set with Loctite 620 which has a vicious grip and gentle application of heat to the surrounding aluminum is highly recommended, use a heat gun --not a torch. The new assembly also must be locked into place with the same loctite 620.
