Old 05-10-2013, 12:12 PM   #6
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: 04 Vue Power Steering Issue, Please Help
Originally Posted by far2grumpy View Post
If you want to proceed - I can provide service manual extracts to access the motor. Send email address by private message.
The thumbnails in my last post were not as good as they should have been.
I've attached updated versions to this post.
You could use photo of PSCM and EPS motor with the connector layout - along with the 04 Vue - EPS schematic in post # 3 - to decide where to attach your volt-meter or test leads.
Send PM if you want the instructions to access the EPS motor.
I know this appears complicated - and it is - there are no simple solutions for the DIY'er.
I'd try to eliminate a poor connection as root cause of the intermittent EPS operation. And, if that fails - parts substitution is next step.
