Old 06-15-2011, 07:46 PM   #10
Blacktree
Blacktree will become famous soon enough
Default Re: The Daily Driver Project
The A/C is fixed. WOOHOO! Good thing too, because temperatures here in Florida are reaching the upper 90s during the day. For example, today it was 97F degrees, with a heat index of 103. Blargh!
Next up is the spare tire.
BTW, I'm pretty sure the oil leak is from the rear main seal, or the rear section of the oil pan gasket. You see, when I first bought the car, I degreased the engine pretty thoroughly. That was over a month ago. The only part of the engine that has oil on it now is the back end of the oil pan. Everywhere else is clean and dry.
BTW, the rear main seal got its name from the fact that it's on the "rear main", which is mechanic's slang for the rear-most crankshaft bearing journal.
Add to Blacktree's Reputation
Rate the quality of this post and help Blacktree reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blacktree is offline   Reply With Quote
