Old 07-04-2019, 08:28 AM   #5
David R
2009 Astra XE
1997 SW2
Default Re: XE Rear Doors - Wiring
I do believe you're right that it is PVC insulation on the wires. Unfortunately by the time we found out there was an issue, it was to late. One doesn't think of preventative maintenance on a car as including treatment of the wires. Well maybe the connection points.
I will try your trick on some alligator test leads I have. All the boots for the clips have become so hard I can't squeeze them, much less use them.
Thanks
2009 Astra XE 5sp 200K km
1997 SW2 DOHC Auto 330K km - Stored for winter, used in summer
Add to David R's Reputation
Rate the quality of this post and help David R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
