Old 10-15-2018, 09:41 AM   #1
Thor4SL2
Thor4SL2 is on a distinguished road
Thor4SL2's Avatar
Default Evap Purge valve solenoid
The vacuum line to the Evap Purge valve solenoid on my 1995 SC-2 is broken and cracked in several places. I want to replace it w/ a flexible vac line but can't see where it goes and none of the service manuals I have give a clear view of it. It appear to be underneath the intake manifold and above the starter.
It looks like the only way to access it is from below by removing the starter. Any body have a photo or suggestions on how to do this? Also the car is running very rough, almost stalling etc. Would the problem w/ the vac line cause this? Thanks.
It's not what you know that counts,
it's what you think of in time!
Add to Thor4SL2's Reputation
Rate the quality of this post and help Thor4SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thor4SL2 is offline   Reply With Quote
