Old 01-13-2017, 02:22 AM   #13
Default Re: Cooling Fan Runs Constantly 2003 Saturn L200
Originally Posted by jerseybrat99 View Post
Is it true what the seller on Ebay told me? That at has to be the same part number or it won't work???
The listing at RockAuto is accurate and doesn't require one to know the part number of the original FCM in order to receive the correct replacement part. For comparison's sake I've added some links to show you the part numbers from a favorite OE parts site and RockAuto between your car and mine.
http://www.gmpartscenter.net/auto-pa...ng-system-scat
http://www.rockauto.com/en/catalog/s...l+module,12955
As you can see, the part numbers from the OE source and the aftermarket source did not change from 2000 to 2003. In neither case did the cataloging request further information to correctly identify the proper replacement part. IMO, the E-Bay seller is inadequately informed about the part history and cataloging.
And do you think I should replace my thermostat??? I was told there really aren't trouble codes to tell if it's bad or not....
It is true that there are no trouble codes which directly detect the failure of a thermostat whether due to overheating, or in failing to allow the engine to reach and maintain its operating temperature. The latter item is, of course, your situation. I believe you would be best served by replacing the thermostat. Here's why: if you replace the Fan Control Module while a bad thermostat is still in use then the new FCM will behave as the old one did. You want to insure the success of this repair to the greatest extent possible so that your car's heating and emission systems function as designed.
Thanks for all the info guys....I'm a single female raising my grandchildren and really need my car...grandson is special needs and we make frequent trips to Delaware so I need a reliable vehicle...while I know a few things about cars and certainly not afraid to get my hands dirty...there are a few things that stump me....
God bless you, jerseybrat99. You're a good woman!
322,000 miles - Holy canolli!
Add to pierrot's Reputation
