Re: SL2 Water Pump Replacement w/PICS
For safety, before replacement of water pump, you should disconnect the negative pole of battery, open the radiator cap.
After replacement, connect the negatove pole of battery, fill up the radiator with the coolant.
Opening the radiator cap help you get no problemn with bubble in radiator.
Tks for share.
Rate the quality of this post and help trantrongthivn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
