Old 07-05-2009, 05:10 PM   #79
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default Re: Cleaning EGR Valve (with Pictures)
i restored my bad EGR valve with sticking valve etc...
I had used solvents but problem would keep coming back in a month.
finally, I thought maybe the shaft clearance was too tight causing a bind on the smallest amount of dirt. SO, i made a slurry of equate toothpaste, (use toothpaste with grit not gel), filled up the cavity, took a power drill and torx bit and spun that valve around till it was good and free. I have not had to do anything to it for about a year now.
My gasket eventually wore out so I just used some silicone gasket maker for the gasket. I whacked out all the slippery soft graphitic stuff out of the metal gasket and smeared some silcone into it.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
