11-23-2007, 09:36 AM
#31
1996 SL1
Re: S-Series Automatic Transaxle "Reverse Slam Cure-All"
Originally Posted by plastic torpedo
I think the selector pin you are referring to is in fact the manual valve. Don't touch that disk, that's the boost valve. It will put a hole in your head if you try to take it apart without knowing there's a huge spring under great pressure in there.
In this picture the manual valve is the "stick" sitting next to the valve body:
And in this one you can see where it slides in inside the valve body:
Do you have to connect something to the manual valve, and what about this manual shift selector pin?
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
