Old 11-06-2007, 07:48 PM   #25
MotorMan
MotorMan is on a distinguished road
Default Re: S-Series Automatic Transaxle "Reverse Slam Cure-All"
19. Using extra care not to damage the bottom gasket move the new Valve Body into place. At the same time lift the Manual Valve Link slightly so it is inline with the corresponding hole in Manual Valve. The plastic clip must face toward the front of the car. Now carefully place the Valve body in position.
I've pulled a valve body out of a junkyard, and I am unsure of the reference to the Manual Valve link. Also, the plastic clip? I've been searching for a schematic so I make sure this is installed properly. At the junkyard, it unbolted and slid out easily.......did I miss something?>
Add to MotorMan's Reputation
Rate the quality of this post and help MotorMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MotorMan is offline   Reply With Quote
