Old 11-10-2017, 02:37 PM   #18
Default Re: Used transmission installed, but shift pattern is wrong.
Generally any type 1 VB trans will only work to replace a Type 1 VB trans as the case is different along with the VB and the TCU. The change is in the 93 model year and is VIN dependent. Beyond that most but not all from 94-02 either economy or performance auto trans will swap. So a 91 is not going to work correctly. Do not depend on the 01 TCU to be intelligent enough to set any useful codes in these conditions. The OP must actually determine exactly what trans is in the car. As has been pointed out multiple times the JY is usually completely clueless.
