Old 10-16-2017, 09:18 PM   #13
5littlejoe5 is on a distinguished road
2000 SL1
Default Re: Used transmission installed, but shift pattern is wrong.
Originally Posted by billr View Post
Check resistance of the five solenoid coils. Can you read live-data? That will a save a lot of guessing/testing of things like the range switch, linkage adjustment, VSS, turbine speed sensor, trans fluid temp sensor. You have already check the three fuses for the trans, of course...
I did check and change the five Solenoid coils. The ones that were installed showed less than 4 ohms each. The ones that I put in showed 5.1 ohms +/-1 ohm.
I just purchased a OBDII diagnostic tester that is supposed to work with an app on my telephone. I've never used one, so I still have to read the directions, and make it work. But, yes, I should be able to read live data. I made need help interpreting it.
I have no owners manual, but just downloaded a shop manual, which I'll have to study. "1997-2002_Saturn_S-series_Repair_Manual.rar".I hope it will have a chart that will show me which fuses to check. Or I'll just check them all.
I'm likely to be at least a few days on this. Thanks for the info.
Add to 5littlejoe5's Reputation
Rate the quality of this post and help 5littlejoe5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
5littlejoe5 is offline   Reply With Quote
