Old 10-16-2017, 07:36 PM   #10
billr
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Default Re: Used transmission installed, but shift pattern is wrong.
Check resistance of the five solenoid coils. Can you read live-data? That will a save a lot of guessing/testing of things like the range switch, linkage adjustment, VSS, turbine speed sensor, trans fluid temp sensor. You have already check the three fuses for the trans, of course...
Add to billr's Reputation
