Old 10-14-2017, 08:13 AM   #4
Default Re: Used transmission installed, but shift pattern is wrong.
Are you sure it's a MP6 transmission?
Are you sure it's a '98ish-'02 MP6?
ID guide attached (same location & scheme for the 5spds they're just MP2/MP3 for SOHC/DOHC).
I had a '00 Subaru Legacy Outback that needed a rear subframe...the idiot NC yard I picked sent me not one but TWO front sub-frames before telling me I didn't know what I was talking about. Oh well, the fronts rust out nearly as quickly as the rear's up here...got my money back and then some
