Thread: High Idoling
Old 09-21-2018, 03:36 PM   #3
toggenburg
toggenburg's Avatar
Default Re: High Idoling
When you went into the throttle body and the TPS, did you look at the IAC, it's right there?
I would replace the IAC and it should be a-ok.
Idle Air Control sensor= IAC
