Old 12-28-2019, 06:25 PM   #8
Core-Lokt
Core-Lokt is on a distinguished road
Default Re: Door Lock Questions
I had a new key made today, and it almost works the doors, but doesn't even turn in the ignition. If I've posted the link correctly or have the privilege, one can clearly see the difference in key profiles. It's possible the Chevrolet dealer tech didn't make quite a correct key where the doors will manually unlock, but it was just $10.00. Seems fairly clear the ignition has been changed at some point. IDK what I'd do to get the tumbler sequence for another ignition cylinder.
Haven't tried to jump across the solenoid, as it's been wet. EDIT: I don't have link-posting privileges until 15 posts made. No matter, as the new and old keys are notably different.
Add to Core-Lokt's Reputation
Rate the quality of this post and help Core-Lokt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Core-Lokt is offline   Reply With Quote
