Old 11-06-2019, 07:10 PM   #2
leviklump1133
leviklump1133 is on a distinguished road
Default Re: RPM jumps up and down when starting
I would clean the Throttle body, if that doesn’t work maybe replace the TPS sensor?
My Saturn had a similar problem, but would rev to 2000rpm and not go down at all ( when first turned on). I replaced the TPS sensor, pulling one from the junkyard, and it has worked well for over a year.
Add to leviklump1133's Reputation
Rate the quality of this post and help leviklump1133 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
leviklump1133 is offline   Reply With Quote
