Old 11-01-2019, 09:54 AM   #8
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
imaddicted2u's Avatar
2008 AURA XE
Default Re: What sensor is this
You might try using a piece of rubber hose that will fit over the piece left behind on the manifold. Put some sealant on it and slip it on. Let it set up. Get a hose coupling to go in to the other end of the hose and cut the connector off of the existing hose and slip it over the other half of the coupling, use sealant or hose clamps if you have to and maybe tywrap it down.
