Old 07-18-2014, 03:05 PM   #8
Signmaster
Default Re: So...someone snuck a Supercharge on my SL1.
Just about anything with a bearing can whine like that. PS, alternator, idler, AC. I don't recall hearing a water pump get like that.
With a screwdriver or mechanic stethoscope you can probably narrow it down. A section of PCV or similar tube will often work too, even rolled up poster board or something.
If you are fairly certain on the noise, you will likely find excess heat and the source of the problem.
