Old 12-27-2012, 08:55 AM   #6
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
Default Re: 2004 L300-1 Auto Axle Seal - Drv & Pass sides
Way to go! I have to look into slotting rear struts because I have a lot of negative camber, though tire place told me it is within spec.
There is supposedly (because I have not been able to find it) a plug on the passenger side of the transmission for checking level. With car level, fill until oil drips from the plug hole. Lots of GM cars use this system, so your mechanic ought to be familiar. I took my car to a shop for transmission fluid and filter after servicing the axle seal.
Also have a 2008 Astra XE
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
