Old 12-21-2012, 08:13 AM   #3
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
Default Re: L300 issues... please help
The starting problem sounds like vapor lock caused by the fuel pump not holding residual pressure after being switched off. Fuel drains back to the tank, heat causes the line to be filled with vapor, and the lock occurs. After the vapor condenses, the car will start. Root cause would most likely be a cracked fuel pump, but it is costly to assume anything. Get a Haynes manual and a fuel pressure gauge and you can test.
I agree with Pierrot to look for other things that might be staying on with the dash lights. Could be connected with the ignition switch circuit. Worst case is a failing body control module. If you search the L tech forum you will learn more about its idiosyncrasies.
Welcome to the forum, and good luck!
Also have a 2008 Astra XE
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
