Old 01-31-2008, 12:35 PM   #5
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
2004 VUE 2.2L
Default Re: 2005 Relay 3 - DVD Problem
I'm assuming that the player works fine otherwise...
Where did the tech disconnect the player? Under the dash, at the player itself? Somewhere else?
Here's my thought - with a multimeter, you could probe the wires where he disconnected the player to figure out which one is the power wire. Then you hook the power only to a switch which you could mount under the dash or wherever is convenient. Then when you want to use the player, turn the switch on. Turn it off when you're not using it to stop draining the battery.
Sure beats $ 1200 for a new one. Just a thought.
Add to john95SW2's Reputation
Rate the quality of this post and help john95SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john95SW2 is offline   Reply With Quote
