Old 05-27-2011, 06:15 PM   #8
TonyUFN
TonyUFN is on a distinguished road
Default Re: trans swap VTI to 4T45E... do-able ?
We're in the same boat. Fighting with the extended warranty company over it too... worse than pulling teeth. they obviously don't want to cover a replacement of the VT25.
I considered the Ion swap article, but considering he used the mounts from the Sedan's AF23... I'm not sure how either the AF23 or the 4T45 would work out. Maybe some fabrication too.
The other question that I have is the communication with the other systems. I know with other brands, the gauge cluster is tied in there as well. So I wonder about the same issues.
Swap trans, ecu, bcm, wiring(?) and mounts(?)...
Since I'm in this boat, I might as well get to experimenting. Just researching a little more. But I'm thinking the mounts might be the major issue.
Any thoughts?
Add to TonyUFN's Reputation
Rate the quality of this post and help TonyUFN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TonyUFN is offline   Reply With Quote
