Old 05-16-2010, 11:18 PM   #45
off-track
off-track's Avatar
Spent the afternoon cleaning the engine compartment (sans engine). Removed the TAM bracket and cleaned the coolant tank as well. Should the heater core outlet pivot at all where it leaves the firewall?? I never realized before that the PS pump reservoir was actually white?!? Pressure washed all the random bit and pieces. Most all cleaned up really well but did notice that the lower dog bone (passenger side) was really rusted. Seems somewhat odd considering all the oil residue in that area (I think the front seal was leaking as well). Should I just paint it or does it need to be replaced? Appears to be solid.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
