Thread: Vue Maintenance
Old 11-18-2017, 08:03 PM   #2
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
Default Re: Vue Maintenance
For the tire, you absolutely want to replace it. If your other tires are ok, you might see if a shop has a used tire in the same size.
The serpentine belt is something I would recommend as well. Especially if you are starting to see cracks in it. Having that blow out on the road is not fun at all.
The pricing on the compressor sounds about right. It may be repairable without having to replace the entire compressor though. I would get another opinion on that. Did they actually perform a leak test, or are they just "eyeballing" it?
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
