Old 03-15-2004, 08:10 PM   #3
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
2000 Saturn LS2 V6-181 3.0L DOHC VIN R SFI
Top - Vehicle
Powertrain Management
. Computers and Control Systems
. . Testing and Inspection
. . . Testing and Inspection Procedures
. . . . Trouble Code Diagnostic Charts
. . . . . P0171
Notes
P0171
A closed loop air/fuel metering system is used to provide the best combination of driveability, fuel economy, and emission control. In this system, short term fuel trim is accomplished by the ECM rapidly responding to the oxygen sensor readings. These changes finely tune engine fueling. Additionally, long term fuel trim is determined by trends in short term fuel trim, and serves as a coarse tuning mechanism for engine fueling. Fuel trim values near 0% are ideal. As the value increases, this indicates that the engine is in a lean state. Smaller values indicate a rich state of operation. The ECM in the vehicle stores fuel trim values for three different speed/load ranges: one at idle and another at medium speed/load, another at high speed/load. This code sets when the fuel trim is excessively high in any of the three speed/load ranges.
DTC PARAMETERS
This DTC will set if closed loop is active, and the following fuel trim limits lave been exceded:
Idle: 7.7%
Medium speed/load: 21%
High speed/load: 21%
DTC P0171 is a (type B) DTC
DIAGNOSTIC AIDS
The following are malfunctions that could cause a lean condition:
Vacuum leak
Fuel pressure low
Poor fuel quality/water in fuel
Exhaust leakage around manifold or front O2S sensor
Fuel injectors clogged.
IMPORTANT: If the front oxygen reading is greater than 1.2, and the rear HO2S is below 300 mV all the time, the O2 sensors are probably not at fault.
Copyright 2004 ALLDATA LLC
Terms of Use
Top - Vehicle
. . . . . P0174
Notes
P0174
DTC PARAMETERS
Idle: 7.7%
DTC P0174 is a (type B) DTC
DIAGNOSTIC AIDS
Vacuum leak
Fuel pressure low
Exhaust leakage around manifold or front 02S sensor
Terms of Use
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
