Old 09-23-2011, 06:07 PM   #8
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
Default Re: L100 fuel tank leak
without a service manual at hand and past experiences with other types of tanks, there should be two metal straps that wrap around the tank. one end should be hinged and the other should either have a nut/bolt. best way to do it is on a near empty tank. this requires a lift or the car being high on jack stands. the tank has to be properly supported and lowered slowly to the point that you can access the lines on top. carefully disconnect the clips on the lines and the electrical connection plugs. finish by lowering the tank all the way. you will see the top of the tank where there you can further determine the leak. also check all of the lines for a possible vibration wear down and the fittings for cracks. other than that, I don't have a book to follow, only past experience.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
