Thread: A/C woes
Old 07-06-2016, 01:02 AM   #3
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: A/C woes
If the system is producing cold air, but it's not keeping up,
here is a shade tree mechanic's way of fixing...
Add a can of PAG oil, it is actually 1 ounce oil, one ounce R134a, and one ounce "performance enhancers".
Do this only once in the life of the car, the system will drown!
http://www.walmart.com/ip/PAG-100-wi...harge/16888788
You will need a set of can taps to add, they are $20 or a six pack of favorite beverage for a friend...
Also, check the Schrader valves, the ports you add freon, for leakage with soapy water. Known failure point...
Done this to several teenaged (or older) cars, with good results every time...
NGK BKR6E-11 spark plugs
