Old 06-14-2019, 09:07 AM   #10
Default Re: No start, no spark
Did you check for fuel in each cylinder? Repeated starting attempts should flood a cold engine with fuel. Remove plugs and examine them for wetness or smell of fuel to verify injectors are operating. One injector fuse powers all injectors, labeled as IGN/INJ 15A.
If I'm not mistaken, all 2.2L engines share the same EFI system configuration. I included a copy of ignition wiring, crank sensor and description of the EFI system from '05 service manuals.
