Old 04-07-2010, 05:12 PM   #30
mrclean92124
mrclean92124 is on a distinguished road
1996 SL2
Default Re: Changing a Front Hub/Bearing on an S-Series (with pictures)
Anyone know where to order just the balljoint dust boot for a 96 SL2??? I'm having no luck finding.
Update: I found THIS thread to be very helpful...including part numbers. Seems a generic boot is adequate for both tierod ends and balljoint. One tip was NOT to use pickle fork to separate lower control arm.. just use a crowbar or other instead:
Use a long crow bar, wedge it on top of the LCA and below the sway bar.. then put a lot of force/stand on the end and it should pop the stud out.
PS: Nothing like a quick post to assure that hours of fruitless searching immediately morph into a search hit. LOL
Thanks.
Add to mrclean92124's Reputation
Rate the quality of this post and help mrclean92124 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrclean92124 is offline   Reply With Quote
