Old 09-07-2007, 04:45 PM   #17
madpogue
1996 SW2
Default Re: Cleaning EGR Valve (with Pictures)
Glen, yes, the electronic EGR valve is pretty big. You can test the movement of the pintle by pushing on it GENTLY with a screwdriver tip or the like.
Rlhdg... (why didn't you buy a vowel?), the EGR valve is a little further back on the SOHC, on the intake manifold. But the directions are pretty-much the same. When you remove the air intake tube, you'll see it.
