Old 07-16-2013, 10:43 PM   #4
jk3006
jk3006 will become famous soon enough
Default Re: Replaced clutch - Now clutch pedal too light and engagement not correct
Rock Auto # 04193 (04-193). Definitely different from the LUK clutch for my '96.
Not sure what I did, but I pulled the pedal up from the position it was naturally resting in. I heard and felt a "pop" of sorts. Now the pedal has no or very little reistance to swinging WAY back and up. I must have popped a clip or something, but I don't know what it was since I'm not familiar with the pedal mechanism (never worked on it before). Or did I do something to the slave system?
Forgot to add that when I pulled the pedal back to see if it had "bottomed out" so-to-speak, it did move an inch or two (where I think it should be). Then the "pop" happened when I forced it further.
Add to jk3006's Reputation
Rate the quality of this post and help jk3006 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jk3006 is offline   Reply With Quote
