Old 05-20-2012, 09:25 AM   #1
wobbles1
wobbles1 is on a distinguished road
1998 SL
Question Check engine light need help
Hello, i need some help, i own a 98 saturn sl
i took my car to be inspected, got these errors :
P0107 Map sensor low input - since replaced
P0117 ETCS - its fubar i tried replacing it and it broke off flush my mechanic doesnt wanna drill it out.
P0122 TPS - since replaced
P0301 Misfire 1 - since replaced plug
P0327 Knock sensor - havent checked cuz it detected misfire
P0341, P0340 Cam position sensor ''A'' circuit - i dont have a clue what this means, i know the 98's used cylinder 4 as the cam sensor, so what is wrong?
i had autozone read codes after i replaced those mentioned above, now i only have P0117, P0341, P0340.
any ideas what i can do to fix this, mainly the cam error. could the ETCS be causing the cam error? any help would be greatly appreciated also i tried having ignition module tested at autozone apparently they dont have the connection for mine, figures. thanks
Add to wobbles1's Reputation
Rate the quality of this post and help wobbles1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wobbles1 is offline   Reply With Quote
