Old 07-28-2013, 09:38 PM   #2
Default Re: cruise control swap, 2000sc1 to 97sc1
Cruise option is turned off by default unless it is listed as an option and installed. You wil have to use the gen - 2 switch pod with your wheel. I don't think you can graft the 2000 wheel onto a 97 but if that is possible someone will speak up I am sure. To get cruise enabled is either locate a Tech-2 scanner or find a dealer who will re-flash your PCM and set it enabled. The big search box in the top middle of the page will dredge up much info on this.
