Old 01-29-2020, 02:09 PM   #50
can0fspam
Default Re: Unknown engine noise when cold
For documentation purposes:
I replaced the timing chain and the noise disappeared entirely. I haven't yet diagnosed what part of the timing set went bad. I'm guessing it was the tensioner because it wasn't quite fully extended (so the chain probably wasn't too long). The guides were both worn in pretty deep too.
If your car makes a noise like my videos - even if you remove the serpentine belt - it's probably your timing chain.
Add to can0fspam's Reputation
Rate the quality of this post and help can0fspam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
