Old 01-10-2020, 09:33 AM   #47
can0fspam
Default Re: Unknown engine noise when cold
Originally Posted by toggenburg View Post
Yes, ~22% ATF in all oil changes.
Tell you what, here is a direct quote right from marvel mystery oil's website itself.
"For example, if your engine has a 5-quart oil capacity, replace one of the quarts with a quart of Marvel Mystery Oil. Repeat at every oil change for optimal performance. Marvel Mystery Oil can be added to engine oil 300 to 500 miles before your next oil change to supplement sludge removal and enhance engine cleaning.
How to use - Marvel Mystery Oil
https://www.marvelmysteryoil.com gasoline-engine automobile"
I repeat, iv'e done this with any brand ATF for decades. Each oil change on all my cars and kids vehicles too. Even on my Audi 5000S and '68 Corvette with IIRC the L88 engine.
Only then, when they would rust out (Chicago rust belt) would I get rid of the vehicle, and even then, their engines had never, never needed any internal work done even up to 331,000+ miles on that engine.
You can lead a many a car owner to water (truth), but you cannot get many to drink (to actually overcome fear and to try something different that works).
Are you saying you replace a quart with ATF before changing, or you put in ATF with fresh oil for the entire interval?
I could see the first one working well but I would be concerned about the weight of the ATF for the second one if it's that much of your oil.
Add to can0fspam's Reputation
Rate the quality of this post and help can0fspam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
