Old 12-31-2019, 04:32 PM   #20
Default Re: Cylinder 3 misfire & Fuel in Oil
Most here aren't aware that uploading snapshots may be problematic for only one reason - the majority of digital cameras and cellphone snapshots create large file sizes too large to upload as attachments here. Examine each snapshot file size. Attachments here are limited to 150 kilobytes file size. Most images are in several megabytes so they're not accepted as attachments. The solution is to use imaging software like Windows Paint or similar image handlers to resize the file for acceptance here. If it's a jpeg file, you can resize to less around a megabyte and be accepted. Experiment then if an upload is successful, press the preview tab to see a screen to display your snapshot(s) then click on it to see how everyone will see your snapshots. If you get this far, edit as much as necessary then press the submit tab.
Size matters between between successful uploads or not.
