Old 12-20-2019, 06:22 PM   #6
billr
Default Re: Cylinder 3 misfire & Fuel in Oil
It means the cylinder head will have to be removed and refurbished/replaced. Minimal cost is about $100 if only one valve is replaced and you have free labor. At the top end, I'm guessing about $750 if a shop does the R&R using a quality rebuilt head and you get a warranty. Lots of possibilities in between, but that is the range.
PS: I'm a bit worried about that "gas in the oil". Generally, a bad valve won't cause that. I'm thinking something else is wrong that resulted in the bad valve, and possibly a bad cat converter by now. You may fix the head only to find there are other problems and costs. This could get expensive, more than the value of the car.
Add to billr's Reputation
