Old 12-18-2019, 05:53 PM   #1
Manospeed
Manospeed has a spectacular aura aboutManospeed has a spectacular aura aboutManospeed has a spectacular aura about
Default Mileage check-in...
Let's see how many of us are still running.
Year: 2007
Engine: 2.2 liter
Mileage: 149,000 miles
Mechanical Issues: None
Work done:
Timing chain, Coil pack/boots, ECM, spark plugs, struts, front brake pads, front wheel bearings, inner/outer tie rods, valve cover gasket, Rear drums + internal hardware, rear brake lines, crankshaft position sensor, transmission filter replacement, pan magnet replacement, transmission fluid replacement, water pump, thermostat, stabilizer bar links.
This vehicle has surprised me. Never in my life did I think it would still be running, but with a little investment in time/money we've managed to keep it going strong. Cosmetically, I need to get the cabin headliner repaired as its begun falling down from the windshield on back by about 2-3 inches. The rear wiper has stopped working as well, but otherwise I feel this vehicle still has plenty of life in it. Oil changes are full synthetic every 6,000 miles.
Way things are going, I believe subframe rust will be the reason this vehicle is retired and not anything to do with mechanical issues.
Add to Manospeed's Reputation
Rate the quality of this post and help Manospeed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Manospeed is offline   Reply With Quote
