Old 12-05-2019, 09:25 AM   #11
454cid
Default Re: Need screw in fitting for water heater hose, dr. side
Originally Posted by TomM96 View Post
The hosebarb/nipple needs be galvanized steel/iron Not plastic or bronze or brass. Actually Aluminum might be available, and might work... but i'd stick with the original zinc/galvanized steel/iron.
What is your argument against brass? I've got two brass fittings on my truck.
1999 Chevy K3500
Add to 454cid's Reputation
