Old 12-03-2019, 05:14 PM   #7
Cavell
2003 VUE 3.0L
Default Re: 2003 Vue AWD V6 Timing belt
well, you could take off intake and pull heads as it would make removing the shortblock a bit easier. and than replace the bent valves. if you can pull the motor you can do the heads. valves are cheap. i think i got all the intakes for 60? unbolting the cats from manifolds is not fun. than you find out you need to remove 2 of the cams to unbolt the heads from block. and reverse process to install heads. the 3.0 is a picky motor
Add to Cavell's Reputation
Rate the quality of this post and help Cavell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
