Old 11-16-2019, 12:47 PM   #3
Default Re: 2007 Vue rear washer works, but not front washer.
Other members posted snapshots of the windshield washer reservoir. Driver's side fender well (after removing the wheel well splash shield). If the washer filler neck is on the driver's side then the reservoir is down below it. If on the passenger side then on that side. Removing the wheel well splash shield should reveal full access to the washer, pump(s) and wiring. Once access is available, someone can try turning on front washer while you check for pump operation. If the pump doesn't run (slight hum when running) check for power (fuse blown?) and if the connection to pump is loose or corroded from weather/road exposure to road salting.
